2002 wellcraft 5.0L, alpha gen 2 drive.
i get a howling noise in gear between 1500 and 3500 rpms, the sound like rips through the boat with its high pitch. it also shakes pretty bad at low rpms on sharp turns.
the gear oil is free of water, in fact its as clean as it was when i changed it last year. i changed the prop also.
i get no shakes or howling over 3500 rpms, and no shaking on sharp turns either as long as im 3/4 to WOT.
My boat has low hours, and its well maintained.
gimbal bearing? maybe and or u joints?
also odd, it vibrates in neutral all rpm range.
any help would be appreciated! and i did scan through the posts regarding these problems. the vibrating in neutral throws me off.
thanks and happy boating!
