Re: Oil Resevoir on 1985 Johnson 88 hp motor
Unless the engine has been converted back to premix, there will be two lines leading to the engine, one for gasoline and one for oil.
If it exists, trace the oil line back to the oil tank. If you've just bought this rig, check with the previous owner to find out what he may have done in the way of conversion if any.
I strongly suggest that you do not run that engine on plain gasoline unless you're sure that the VRO (automatic oil system) is intact.
