64NHALF
Thread starter- Joined
- Jun 26, 2007
- 25
Ok I know I saw somewhere in this forum someone who had the same problem I do, but I have looked at so many posts I can not seem to find it again, even after using the "search" I can still not find it or see it. OK so here is "my" situation, When I first got it running, it would not keep a slow/low idol, so with a bit of trouble shooting I figured it was sucking air and causing it to stall, changed out the "o-ring" and problem solved..... so with the motor in a 55 Gal drum (cut down to about 35 gal) filled with water, it will run at idol for 5, 10, 15 minutes with out a problem, so today we take it out to the lake to do a little fishing. Get the bout into the water, start the motor, works in reverse, works in forward, open her up, it runs great for about 2 minutes, then dies! wait a minute, starts up, runs for another min or so, then dies again! will not stay running while in gear, put it in Idol again , and it keeps going like an Energiser bunny. Please help any sugestions
