How to release steering cable from helm ?
roscoe
Replacing my steering cable.
Helm is a teleflex rotary unit from approx 1977.
I have disconnected the cable from the motor end.
Have removed the large coupling nut from the helm end.
But need to know how to release the cable from the helm.
I know when you feed the cable into the helm, there is some sort of a locking device which locks onto the cable. How do you release it ?
Is there some trick here that I am missing?
thanks.
reelfishin
Re: How to release steering cable from helm ?
There's a slide pin or tab that you have to push in to release the end coupler on most. It's either a hole or a slot that releases the cable.
there is a hole on the back side of the red circle, you push a small pin into it. this releases the cable and turn the steering wheel. click picture to enlarge.
roscoe
No pin, tab, hole, button, etc.
I just grabbed the greasy cable part and gave it a yank, out it came. !
But thanks for your help.
that's strange, had to be something to hole the sheath, so the cable would slide in side.
roscoe
Yes, the sheath was attached with the coupling nut.
But after I removed the nut, and moved the junk out of the way, all I had to do was pull the remaining foot of cable out of the helm. I was lead to believe there was a locking mechanism holding the end of the cable into the helm.
that explains it. that is a very old style helm. on the quick connects you just push the pin, give a little tug, and turn the wheel and the cable comes right out.
