454 magnum problem stalling problem
Tripps007
Boat starts and runs fine for about 30 minutes then power dies when idelling. Thought it might be water in line or fuel filter, so replaced filter and put in a stabilizer...to no avail. Bilge is not full. Can't figure it out and its driving me nutz. Does anyone have any suggestions?
Don S
Re: 454 magnum problem stalling problem
May just need a tuneup, carb adjust, carb rebuild, choke problem. Impossible to say with out some more information. Like Year, Carbed or injectied, etc.
180shabah
If you had water in the fuel, You still have water in the fuel. Adding stabilizer to the gas did nothing. If you have a water seperating fuel filter, dump the contents into a glass jar and let it sit. You will then know if you have water in your fuel.
nobby clark
Leaking gas cap,ethanol fuel,samlle amount odf gas related to air. used to fly and no 1 check always used to re check for water in fuel.
