HELP!! Got the 1977 Mercruiser 165 out of storage yesterday. Installed the battery, vaccumed, greased the lower unit splines, u-joints, and greased the trailer. Took it out to the lake for a test. Started right up and run great. Put it into reverse to back off the trailer, and it died. Tried again to no avail. Put it into forward and it works just fine. It just dies going into reverse. It wasn't doing this last year. So home I went and got out the old Seloc manual and worked from 9 to midnight trying to adjust the cables so the shift interrupt would not trip going into reverse. I got it so that it is real close to not tripping the switch. I have read other posts on the matter and they say to replace the lower shift cable. But, I just replaced mine in the spring of 04 and it still moves easily by hand from forward to reverse. So I'm thinking that's not the problem. I used the Seloc method to adjust the cables and also tried the mercstuff.com/images/shiftcable.jpg method. The mercstuff method worked much better and that is how I have it set now. I am going to try it out in the water after work tonight to see if it is close enough to work. The frustrating thing is that the unit is locked fully into forward and reverse; it is just the matter of getting that interrupt switch to work right. Please help! Thanks.
