kiddynomite
Thread starter- Joined
- Jun 28, 2007
- 6
I have tried searching these symptoms before I posted but can't find the identical topics discussed here, and, I have posted some round about questions the past few days hoping not to take up too much of anyone's time and/or brain cells - but I'm thoroughly stuck.
I have a 1982 Evi 70hp - the last time it was in the water was 5-6 years ago and it ran fine, minus a little hesitation when you dropped the hammer (1 second worth). I have finished rebuilding/painting the boat recently and I put it in for a "sea trial" and it started right up, idled awesome and cruised out of the launch site fine. The problem is when you try and run it wide open - it goes maybe half speed (that's a guess, I have no tach or speedometer).
I had a small leak when I primed the tank tight at the motor that went away after a second or two or it started running. I cleaned the carbs and the bottom two were pretty well gunked up, the ignition system is firing good - the middle plug is a litle wet while the top and bottom tend to be dry(er). The compression is right where the book says it should be and still, the exact same problem. It didn't run any better after we cleaned the carbs - which sealed up nice and fine but a little gas drops down from them when it runs but I can't pin point it.
That's all the information I can think of off the top here, any and all help will be greatly appreciated.
