Where to get transome shiel gasket
mtnrat
Where can I order online a transom shield gasket for a Volvo 280B. No boat shop for many miles. It is somewhat square in X-section. Also if I should use a sealer, what sealer should I get.
Don S
Re: Where to get transome shiel gasket
They are round in cross section, and comes to you as a rope, cut to length (just a little long to make the butt joint tight) and glue together at the top of the transom shield about an inch or two off center.
You can use rubber cement, bellows adhesive, contact cement or about anything to hold it in the groove while you mount the shield. Sealers aren't necessary.
897726 is the Volvo part number. It's one of the #20's on this site.
http://dougrussell.com/partscatalog...,2261,2262,2263,2264,2265,2266,2267,2268,2269
mtnrat
Thanks. What sealant should I use around the bolts and when reinstalling the drain plug?
