Throttle/Shift safety wiring?
rost495
Have a throttle/shift setup, has TNT with it. Have those wires ID'd no problem.
There is a micro looking switch inside the unit, has 2 wires coming out of it. Have no clue where they go to. Boat was bought torn apart.... I'm guessing a kind of neutral switch??
Where do they go and how to hook them up?
THanks, Jeff
jtexas
Re: Throttle/Shift safety wiring?
If its a neutral safety lock-out, it'll be closed when the shifter is in neutral, open otherwise, and will be wired in series with the "S" (start) terminal on the keyswitch, a yellow/red wire on most boats.
rost495
Forgive me, I'm in over my head, just know enough to be dangerous and cheap....
In series meaning I find the yellow/red wire, and interupt it with these 2 wires? Like putting a light switch in place or same as what I'm thinking I have to do for the kill switch but kill switch goes to the black/yellow wire?
Thanks, this has been a real ride, buying a boat with parts and wires in boxes and the boat all taken apart...
But still fun and not workable without all the fine info here.
Jeff
jtexas
right, you got it. a digital autoranging multimeter would come in real handy with what you're doing. walmarts has one for about $25.
the kill switch works a bit differently, though. One wire from the switch is tapped into the black/yellow, and the other is connected to a ground wire.
Re-wiring your boat - a real labor of love.
rost495
Have an analog meter, so I'm sorta ok. I know more about AC than DC and little about boats...
Got it on the neutral switch and the kill switch. Do not have any batteries yet, have a 12V gel cell from the deer feeder that I get current from to test a bit, but it won't even honk the horn... so I'm wiring away trying to get it all settled best I can and then get 2 good batteries and offer a prayer up...
I have a question about the sending source from the motor for the tach in the Johnson forum FWIW, in case no one else has answered that one....
I'll be able to say I did it myself though and that makes me happy, with instruction from lots of good folks here!!
Thanks, Jeff
rost495
Well I thought I'd posted it......
94 Johnson 200 HP, where do I find the lead for the tach sending wire on the motor, IE have the tach in the dash, but no wire to the motor?
THanks, Jeff
jtexas
should be a gray wire in the wiring harness
RetNav
"Got it on the neutral switch and the kill switch. Do not have any batteries yet, have a 12V gel cell from the deer feeder that I get current from to test a bit, but it won't even honk the horn... so I'm wiring away trying to get it all settled best I can and then get 2 good batteries and offer a prayer up.."
If I understand the above quote, get you a fire extinguisher and stand by when you put a battery to this set-up. What you do by tying the neutral switch and the Kill switch together is put + battery voltage to ground and it will smoke. Those are two separate circuits.
rost495
Hope its not that bad.... The neutral splits the yellow with red stripe wire, teh kill goes to a black with yellow and the other is black... Not hardly the same wires, but I may not have been clear on that.
Regardless the small battery will test it all out and voltage before I go to a large battery.
Thanks, Jeff
RetNav
It sounded like you had them wired together and just thought I would put up a warning for you. I just finished doing the same project to another boat I acquired and had to research lots to find the right way.
rost495
Thanks for the input, just found out exactly why something on the ingnition harness looked strange with a fusible link, ended up answering a couple of other questions !!!
Its fun, but then pulling all the rigged wiring from someone else, going back a way you understand much better, and then cutting, crimping, soldering, liquid tape and heat shrink all takes time while cramped up under the console.
Jeff
