1979 Johnson 115 - Starts then Dies
LadyinRed
I think I know what the problem but am curious on thoughts for what the engine would start - no problem - but immediately die. The plugs are new and properly gapped and torqued...
Re: 1979 Johnson 115 - Starts then Dies
could be carb, failing power pack, failing coils. what have you found, have you checked compression, spark that will pump 1/2 inch. what do the new plugs look like after this. wet, dry, oily. need a little more info. has the motor been unused for a period of time?
LadyinRed
The engine has not been used for about 6 months and I winterized per the book. The plug compression seems just fine but the plugs were oily when I took them out.
what about spark, you still need to do a compression check as it tell you about the general health of the engine. i check mine twice a year.
LadyinRed
I finally check the pressure and it is in range on all four. I think it is carb rebuilding time??
