77 115 need o rings for LU drain/fill screws
elreydelos
Looks like I may have found the problem with water in my LU. The lower drain/fill plug (screw) has a crappy looking o-ring and the top one does not have one. Does each need need one? Does anyone know what they are called or a part number?
Thanks!
HighTrim
Re: 77 115 need o rings for LU drain/fill screws
They should be changed every time you change the oil,go to any marina or supply store or you can order them right here at iboats. GL
both need them and should be replace each time removed. 333572 will work
