Re: Runabout vs Pontoon
I went directly from a canoe to my first 24' pontoon. I have learned a lot since then. Never skimp on the motor, and never get a single axle trailer for any boat over 20'.
That is not to say I was not familar with boating basics, but I had never owned one or spent a lot of time on motor boats before buying my first one used. I find that towing one is not a big deal. Like all trailers, you have to know where it is as you travel. At 8'6" wide, 30' long, and 10' high, it is not something you go to the drive thru with, but it is not that difficult. I tow mine all the time and with a Dodge Dakota with the small V8.
Manuevering is a bit different than a fiberglass boat. You have two hulls, so it will corner flatter than a V-boat. It will ride more comfortably than a single hull in mild to medium chop. It tends to knife through a lot of waters that most boats junp through. I know a lot of people that avoid most boats, but enjoy going out on mine. Often, we will go out as a group with 2-4 boats and use my boat as base camp, chase boat, or whatever. People often get tired of the smaller boats and trade off to relax on mine. In most boats, you are confined to the seat while moving, but on a pontoon boat, it is easy to move around. Several times, we will grill on my boat while the kids and adults go running around on PWCs, with my boat being a portable dock with shade and seats.
Wind is a factor with pontoons, especially when docking or loading. You have a light load with a lot of area. Practice and a decent trailer will keep you in good shape.
Motors can be tricky decisions to make. You cannot go wrong with a quality brand 4-stroke. OB vs I/O is a personal choice. I have owned both and each have their virtues and foibles. Decide how much maintenace you are willing to do, and find a setup that will make it easy for you to do that. Mercruiser is coming out with the new Vazer engine and drive combo. The drive is a compact, reworked Alpha that is paired to a 100 hp engine. It is designed specifically for pontoons and small boats, to allow it to fit under the deck. How it is received by the public will be seen, but I have seen the test mule and it looks sharp. The only problem might be the lack of more HP options, but the future will tell on that potential.
