Re: MAIDEN VOYAGE!!! motorbolts leaking
it's time to do some serious investigating of your transom. most likely it has been leaking, and you have a rot situation, in the transom, and the stress has loosen the area around the bolts. i have an idea you are in for a transom replacement, either with the wood method, or seacast method. if the transom is still good, remove the bolts and seal with 3m4200.
