Hello to all, my first post, I wish it was on a happier note.
I have a 220B Angler 2001. It has twin 2002 115hp 4 stroke EFi's on it. The motors only have 150 hrs on them. They were used and then sat for almost a year, and barely used.
On the test run they got to high 4000rpms, but blamed it on poor propage
(15P Blackmaxes). Took it out and fueled it up, and noticed a drop of rpms, decided to change the filters, and now the motors will not get over 2500rpm @ WOT. Took it to the mechanic today and he said both engines are only running on 2 cylinders. Checked the coils and they were not the problems.
He claims that it is the ignition system (pcm). Is it possible that this same problem can be occuring on both engines. I just find it hard to belive that both motors have an ignition problem at the same time.
If anyone has any insight into this problem, as it is a holiday here (bahamas) and i wont get to talk to mech til wend.
Thanks for you help
Capt Adam R.
Thanks for you help
Capt Adam R.
