Hi everyone. 1985 26? Sea Ray. Currently, the drain/plug in the transom is the screw in type plug (Garboard Drain??).
Well, long story short, when I installed my new engine, I put on an oil drain line, but it won?t fit through the current drain back there.
I?m thinking that if I had the Snap Drain Plug (the rubber plug that goes in and then you push the little handle over to tightnen it) in there, I would go from a ?? opening to a 1? (or more) opening and that may be enough to fit my oil drain line through.
Would you think that there would be any issues with changing from the screw in/Garboard drain plug to a snap drain plug back there?
