Identify part on older steering linkage
jddenham
Hello,
I would like to know what the circled part is called and where I might be able to purchase one.
It is a late 50's Johnson motor that has been adapted to a teleflex style cable with rack and pinion.
I think I have seen this referred to as a 'heim' ??
Any help will be much appriciated !!
F_R
Re: Identify part on older steering linkage
I believe that is an old Morse steering system? Morse called that part a rod end. Some might call it a ball joint. Morse was bought out by Teleflex. Try a marine dealer. They all have access to Teleflex.
Or try their national retail parts distributor, Charman Enterprises. charment.com/
larky
kinda looks like a tie rod end that you would find on a fourwheeler or snowmobile. if you know someone that has a junk one in the back yard ask if you can "recycle" some parts. probably wont be the same thread but ya might get lucky
ezeke
Thanks JB
jimyoung
You can also find this part at your local bearing distrubitor.....Kaman Industrial Technologies or Motion industries, or Applied Industrial.....can be found in phone book....it is known as a hiem joint by old timers....rod end by most others.....yes i work for Kaman....Fresno Ca.
