firehog6305
Thread starter- Joined
- Jun 30, 2007
- 283
hello folks, I need to pick your brians again
As you know I am restoring a 1978 26ft reinell with dual 305's and omc outdrives, I have to replace one of the carbs still, I replaced the other one already, the carbs run off the same fuel source, which runs through a water seperator filter, now I know that the bad carb has a fuel leak *seals are shot* but the motor with the new carb wont keep running, unless I hook it up to a gas can, there is plenty of fuel in the lines, and gas is new and clean, could it be from the other carp have leaks and allowing air inside the line and the fuel pump cant compinsate??? any idea's????.....thanks tony
