transom jack or too much motor???
lyncraft_mechanic
I have a 1964 lyncraft 14' boat that i just installed a 2002 johnson 40hp outboard with power trim and tilt but here is my problem i cannot open the motor wide open because it pulls water from underneath my steering tube and shoots it directly in to my boat. do you think a jack plate would prevent this from happening? my transom hieght is only about 16" deep and the motor is a long shaft anywheres between 18 and 19 inches long. any suggestions?
reka12
Re: transom jack or too much motor???
The motor may be too low. That heppened to me when repowering. Raised engine and it took care of the water coming back in the boat.
Frank Acampora
Yep! Engine is definitely too low. water rises off the water pump bulge in the case and just splashes over the transom. You need to lift it at least 4 inches; Cav plate should be even with bottom of hull.
lyncraft_mechanic
i am going to the marina this morning to purchase a jack plate so that i can install it today. i will let you know how i make out. i just want to thank you all for your help.
The vintage and size of your boat suggests that you have a 15" transom (short shaft). It may be that the 40Hp motor as a long shaft (20" shaft). You are therefor dragging a bit. A transom jack or jackplate is the fix (or a shortshaft motor)
lyncraft_mechanic
well the jackplate did the trick no more water over the transom. thanks every one for youre input it only took me 30 minutes to install the jackplate and relaunch the boat!
another happy ending. yaaa. happy boating.
reka12
We would really like to see pictures if you have 'em!
