marineman16
- Joined
- May 22, 2007
- 37
I just bought this boat this year and have no clue what may or may not have been done to cause this. Basically, the motor starts with ease, runs great up to a speed of about 55 for a couple minutes, then "surges" a bit while dropping down to running around 40 over the next minute or two. I can feel and hear the bogging occur, but can't find anything on here that matches my problems. Once shut off or even slowed down for a few it will repeat the cycle.
I'm not very mechanical, but I wonder about:
-Fuel pump / fuel filter
-Carbs
-Spark plugs
I haven't checked anything fuel-related yet, but have run carb cleaner through to try to clean everything out a bit. No luck.
The cooling stream (water pump release) is a steady stream but not a hard stream. I have no clue how strong it should be. Either way, it doesn't seem like overheating to me, but I could be wrong.
Does anyone have any input on where to start?
MANY THANKS!!!!!!!
-Carbs
-Spark plugs
MANY THANKS!!!!!!!
