Re: Ted Williams 5.0?
steelespike, you are so right. I tried the ted williams 5.0 last sunday, it behaved exactly as you described, vibrates, is noisy, and appears to be very prone to problems. it started out pretty well, but about 3 hours later I barely made it back to the boat launch. finally getting it started after about 60-75 pulls of the startedr, not to mention the blisters on 2 fingers. but then it would only run at full throttle, as soon as I backed it off a little when approaching the dock, it immediately stalled out. I've been tinkering with it, redid the carb, checking the spark etc. but I'm real close to giving up on it. to be fair, when it was running it moved my little boat quite nicely. any tricks or suggerstions you or anyone else might think of would be appreciated. thanks for your advice, you obviously know what you're talking about.
