FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
I replaced lower unit water pump on a alpha 1 mercruiser 5.7L engine, had in forward gear on shifter. Now it stays in forward gear. Would like to have some insight on what is wrong. Thanks to all for help.
You had it in forward gear on the shifter, but did you have the drive in forward also, did you make sure it stayed in forward.
Raise the drive and see if the shift shafts are in place. If they are, pull the drive back off. The shift slide may have dropped out of the roller.
Now the shift cable will not shift lower unit seems to be stuck. Lower cable jumps out of engine shut off switch. Still cant fix problem. Thanks for all help.
Welcome to iboats........
Pull the drive back off.....
See if your shifter moves freely......
While in foreward your coupler should be in the same position as in this pic: http://www.boatfix.com/merc/Servmanl/6/6A2R3.PDF
In reverse it should be at 45* or so, as long as it does rotate you should be ok......
Before removing the drive, note the shaft & above pictured item.....
They must be engaged, if not I suspect that you have left out the washer that sits over the shift shaft & props up the intermediate shift shaft to prevent up & down play.....
If this is the case you will need to pull the cases apart & put it back on.....
Turn the prop ccw & the shaft CW to lock it into gear & maintain pressure to insure it stays in gear for assembly......
Lower unit, Maybe I did not word it right, sorry. with the lower unit off the remote shift is hard to move, If I take the lower shift cable off it shifts fine. It seems like the cable is frozen. Thanks for all insight.
