mhenchen44
Thread starter- Joined
- Jun 24, 2007
- 9
I've inherited a 15 footer with a 1983 Johnson 60hp outboard. It starts up and idles great but has very little power on the water. I've replaced the impeller for good measure and just recently cleaned and rebuilt the carbs (per a previous suggestion from this board). When I tested it out on the water the same thing happened. As the engine was running, I pulled the top plug wire and the engine kept running the same way. Replaced the top and pulled the bottom wire and I got zapped and the boat quit instantly.
The top plug wire does have a bit of wear and abrasion marks on the elbow connecting to the plug.
I'm thinking about taking the engine into the shop, because the shop mechanic told me that I'd have to purchase special tools in order to diagnose the problem correctly.
Is this correct? Also does anybody know if I can switch the top wire for the bottom one to see if the wire is bad? Is there another way I can test the wire (continuity on a regular tester perhaps?)
Finally, and most importantly, does anybody know some simple tests I might do to diagnose my problem without having to go to the shop.
Any help would be appreciated. Thanks in advance!
p.s. after realizing the problem, I headed back to shore. On my way in, at near full throttle, the engine started to pick up power slowly on its own. Thought this may help with diagnosis.
