OK guys, I?ve consulted all the local experts and no one has an answer for me. Service has a six week backup at the shop. You?re my only hope. I have and overheating problem with my 1989 Mercury 150 HP XR4 outboard. Here?s the deal?.if my water pressure stays around 8 psi (on plane) the motor runs cool, ? on temp gauge. If the water pressure jumps up to 12 psi, which it does whenever it feels like it, it will begin to heat up. Then if I speed up or slow down and the pressure drops back down, it will cool off. So it?s high pressure = heat and low pressure = cool. I?ve changed the water pump (complete) and popet valve diaphram. Also removed thermostats and bypassed telltale. No change with any of above. Compression is 125 psi all.
Any ideas are greatly appreciated. Thanks....Frank.
