droptopgeek
Thread starter- Joined
- Jul 17, 2007
- 4
Hello all I am a long time boater, first time owner and new to the forum.
Brief background:
I recently purchased a 28? 1976 Winner and have found myself in the middle of an unexpected project. Yes when I bought a 30 year old boat I knew there were going to be some projects but I didn?t expect the depth of the projects that my surveyor did not find. I have recently decided that a complete rewiring is the way to ensure that all will work as expected. The boat has duel control station one on the fly bridge and one on in the salon(ish). I am fairly handy and have done most of the engine tuning myself and am planning on doing all of the 12 volt system myself. I am knowledgeable with 12volt wiring in cars but I have never wanted to control my wipers from the back seat and hence the problem. I have asked several knowledgeable marine industry friends people at my local boat store but no one seams to have an idea of how to do this. I plan on having controls for items like the bilge blower, Bilge pump manuals, navigational lights, horn, etc at both stations and then other 12 volt items controlled only from the lower station. A great perk would be if I could insert the keys in the lower station then start and kill the engines from the upper station but that may be my next post.
The question:
Does anyone make a 12 volt 3-way switch and I don?t mean an on-off-on switch I mean a 3-way switch like what you would use in house wiring with a switch lead that runs between them. I would like to be able to turn on or off items from either station. I have been researching relays and possible electronic devices to do this but have not been able to find any help. Example I turn on the nav lights from the lower station and then drive all night to deliver the boat to its new home (this actually happened) then about ? hour after dawn I had to wake up my first mate to turn them off because all I could do from the upper station was flip a switch to send more power to the light. The way it is currently wired the starboard engine battery is the house battery this will be changed as well but for now lets start the circuit there from that point there are one positive and one negative lead (positive runs through a battery switch) running to each station then the positive leads run into a fuse block in the lower station and older console fuses in the upper station. From there they run to the switches at their respective station then on to the load. This works to allow them to be turned on from either station but they can not be turned off from one station if the other station has them on.
Any ideas would be greatly appreciated I can?t be the only person that wants to wire their boat this way can I?
Thanks all
Adam
Brief background:
The question:
Thanks all
Adam
