Re: Value of Hydrofoils
They add about two pounds of weight. Now that you have my opinion, I need to ask if you have a performance issue that you think a hydrofoil would help with. If not, why add something that can actually hurt handling and slow you down. If they were a cure for all handling ills the engine manufacturers would redesign the AV plates to resemble a hydrofoil. If you do a search on these forums for "hydrofoils" you will probably find 90% of the respondents opposed to them and 10% feel they help with something. I am not a RIB (rubberized inflatable boat) owner so I can't vouch for use on those boats, but many users have them, apparently to control porpoising. You said you "have" the boat but apparently have not used it much so I would certainly not add anything until I got familiar with it under all conditions of load and speed. If a performance issue pops up and you've tried all other remedies, then I would consider Smart Tabs before a hydrofoil. I've used them, taken them off, thrown them away and now run Smart Tabs to aid in hole shot, control porpoising, and to allow planing at slower speeds.
