Pushrods/Rockers
jdtower23
I made a mistake by not keeping my pushrods and rockers separated for each cylinder....4.3 OMC '88
What are the ramifications? Anything I can do to remedy the problem?
Thanks,
John
Coors
Re: Pushrods/Rockers
Really fast wear, as they were mated; new pushrods; cheapest.
Don S
Put it together and run it. Try to keep it below 9,000 rpm as much as possible.
jdtower23
So new pushrods would solve the problem completely? What about the rockers? Know a source for the pushrods?
Thanks!
Don S
Use your old ones. Do you for one minute think that all these remaned engines keep them matched??? You don't have a race engine.
jdtower23
Thanks guys....they all look pretty good so i don't think it will be a big deal....engine actually turned out to be in really good visual shape after I tore it down...affected cylinder(head gasket) had a little discoloration but no pitting or anything and piston looked fine....also same cylinder held oil just like the others which had great compression.....
Should I mess with the lifters at all or just clean and put back together?
Thanks
Buttanic
Lifters are a different story. They need to go back in their original location. If you didn't keep them sorted as to where they go you may be looking at a short cam and lifter life. The only good solution is a new cam and lifters.
