TBarCYa
- Joined
- Apr 13, 2005
- 781
I'm looking for advice on adding seats next to my engine cover. My boat is a 21' Regal Cuddy and while I don't have a pic of my boat, the pic below is setup very similar to mine. What I'm looking to do is build some sort of seating into the areas beside the engine cover and while it's not beyond my skills to make a new engine cover with the seats built in that are on the same hinge as the cover, such a configuration would definitely prevent me from being able to move around the engine compartment when the cover is open.
I've got two ideas. One would be to put pedestal seats back there with a permanent base and removeable pedestals so that I can remove the seats when access to the engine is needed. The problem is that there isn't much room for a standard seat so they would most likely have to be above the engine cover which is not what I want. The other idea is to build small boxes out of wood covered in glass with removeable padded lids that could serve as seats. With padded bolsters around the whole stern of the boat, it could be made comfortable and would not be bolted down so they would be easily removeable if access to the engine is required. I'm thiniing that I could use bungee or nylon straps to hold the boxes to the engine cover to keep them from moving around.
Anyhow here is the pic. Like I said, it's not my boat but it's similar. I will post a pic of my boat once my camera is done charging.
