Re: Foaming-1991 -24' Proline Walkaround
Foam in the floor is a bad idea. It comes in contact with water, gets soaked and becomes useless and rots your boat (like I need to tell you this).
Foam above the floor is a great idea! Coast Guard regs now specify that new boats be foamed in such a way that water can fill the space below the floor when a boat is swamped, and the foam is in places like seat bases (like on lounge seats), high in the transom (see those funny big square transoms? they are full of foam) and under the gunnel and in the side walls of the hull. This keeps the boat from flipping over so even swamped, you can still be INSIDE the boat rather than hanging on an upside down hull in the waves.
If you foam above the floor you get the benefit that the boat will not sink (assuming you put in the right amount of foam), the foam will not get wet and cause decay, and your bilge area will completely drain and allow air to circulate keeping it dry and mildew/rot free.
I feel that foam is worth the expense when your life and the life of your family and others is concerned.
