thank you laddies i put some wd-40 in the linkage and worked it for a little while and now it is work just fine . but now i get the motor started and it'll run for a little bit(few second's) and then it'll die.sometimes i can work the choke and ill get it to run for about a minute . any suggestions would greatly be appreciated
Try pumping the bulb if it stays running the fuel pump need to be repaired, if that don't work first try to open the idle adjust ment 1/2 turn and if that helps it needs the carb adjusted and if it don't you will need to clean the carb.
