fishfetchr
- Joined
- Sep 15, 2006
- 24
Hello- I am hoping to get some help here.
Yesterday, at the dock, after having the boat out, I tilted the engine up (87 150 Merc), just about all the way out, it stopped (no more power). I tried up. back down- nothing. Turned the key switch back on- nothing. I noticed that the fuel and amp gauges didn't show readings like they usually do with the "key on". Next, to the battery- I disconnected the cables and brushed them up to clean them up a bit, reconnected and still nothing. Here's the thing, some accesories are working (lights & bilge pump). If it were a weak battery, wouldn't the gauges still "show" with the key on? Could this be a wire coming off somewhere? A fuse? Am I correct in guessing it's something with the trim-tilt since it happened actually during raising the engine out? The throttle is a Morse SL-3 Type with trim in the handle. Funny thing is once in a while when tilting the engine up it would stop briefly, then if I'd let go of the switch and do it again it would be fine.
Also- there is only the one battery hooked up right now and it's less than a year old.
Thanks For Your Time- Just looking for a good place to begin.
Mario
Mario
