Pilot & Maintenance Jokes for your weekend
valkyr
Here are some of the actual maintenance complaints submitted by Qantas' pilots (as marked with a P) and the solutions recorded (as marked with an S) by the maintenance engineers.
P: Left inside main tire almost needs replacement.
S: Almost replaced left inside main tire.
P: Test flight OK, except auto-land very rough.
S: Auto-land not installed on this aircraft.
P: Something loose in the cockpit.
S: Something tightened in the cockpit.
P: Dead bugs on windshield.
S: Live bugs on backorder.
P: Autopilot in altitude-hold mode produces a 200 feet per minute descent.
S: Cannot reproduce problem on ground.
P: Evidence of a leak on the right main landing gear.
S: Evidence removed.
P: DME volume unbelievably loud.
S: DME volume reset to a more believable level.
P: Friction locks cause throttle levers to stick.
S: That's what friction locks are for.
P: IFF inoperative in OFF mode.
S: IFF always inoperative in OFF mode.
P: Suspected crack in windshield.
S: Suspect you're right.
P: The number 3 engine is missing.
S: Engine found on right wing after a brief search.
P: Aircraft handles funny.
S: Aircraft warned to straighten up, fly right and be serious.
P: Target radar hums.
S: Reprogrammed target radar with lyrics.
P: Mouse in cockpit.
S: Cat installed.
And the best one saved for last......
P: Noise coming from under the instrument panel. Sounds like a midget
pounding on something with a hammer.
S: Took hammer away from the midget.
12Footer
Re: Pilot & Maintenance Jokes for your weekend
Very good :D ROF!!
RubberFrog
Some killjoy will soon be here with a snopes link. :(
beerfilter
Lmao.
Read this years ago,still hilarious.
There is also list of "overheard" conversations between planes,and , towers that is also a riot.
True?
I don't care.
It's FUNNY!
:D
