Re: mercrusier injectors shut down at higher rpms
You can check codes by using these instructions;
How to make a Marine EFI Code tool for under $1.00
Materials needed:
One 12volt resistor type LED light
One small paperclip cut in half
This home made code tool will work on most marine EFI systems with the ten pin DLC (Data Link Connector).
How to hook it up:
1) Ignition key ?OFF?
2) Remove the cap from the Data Link Connector (DLC)
3) Slide the LED into the female terminals of position E and F on the DLC, making sure that the positive side goes into terminal F and the negative side into terminal E
4) Turn the ignition key to the ?ON? position (LED should come on)
5) Insert the half paperclip into terminals A and B ? This puts the engine in ?Service Mode? - (you will hear fuel pump come on, and code will begin to flash on the LED)
6) Read codes by observing LED flashs. If the self diagnostic system is working it will flash code 12 ? one flash, pause, two flashes, long pause ? it will repeat three times. If other codes are present they will flash in order of lowest to highest.
For more details on how to read codes, clear codes, what ?Service Mode? is, how to set base timing, etc. refer to appropriate service manual.
I don?t recommend making and using this tool unless you are confident that you can do it correctly. Hooking it up incorrectly could damage the ECM.
Dave
