no acceleration
engine 9
I have 15 hp gamefisher(force), in neutral I can wind it up like a mini bike but in gear it seems to go only half way. Any ideas?
Thanks
F_R
Re: no acceleration
Sure. In 99.9% of the cases that is because it is only running on one cylinder. Cure depends on the cause. Check the compression first. Then check the spark (and spark plugs).
CATransplant
Re: no acceleration
On that engine, it's almost certainly just firing on one cylinder. Pull plug wires one at a time, then restart. The one that won't let it restart is the bad one.
Ignition stuff is available for those Force-based engines.
engine 9
Re: no acceleration
pulled the plugs on wires one at a time and started up fine on both. Just seems to chug along. Seems like the throttle isn't advancing enough(gas) but I really don't know, I'm just guessing. What next?
Thanks
engine 9
Re: no acceleration
did I say 15hp I meant 9.9, probably doesn't make a difference
CATransplant
Re: no acceleration
OK, if you have spark on both cylinders, first check compression on both. If it's OK on both, then it's time to do a complete rebuild on the carbs.
