fuel problem 1967 evinrude
shipwreck
1967 Evinrude manual shift sport four(V) 60 hp
model 60733
I rebuilt the carb , new float, needle and seat.
The fuel runs through the engine and drops out the peep hole on lower unit.( can see trail in water.)
Also replaced fuel line, i get pressure on bulb, just softer than tennis ball.
i didn't hear the fuel squirt through engine, like before with old parts i had replaced on carb.the boat would only go 5mph and die when throttle was increased.
also it blew a spark plug out and i was only running on 3 cylinders, i did not know this. i took the heads off and am going to install heli coils
Question?
Is carb float and needle the only thing i should be looking at?
is there another place i should look?
next question is timing, dose anyone know how to for this model, checked my manual a couple times , it through back and forth.. left me more confused.
good news my lower rebuild worked!
reload
Re: fuel problem 1967 evinrude
When the motor is shut off does fuel continue to run out the front of the carb for a short period of time? With the motor off can you force fuel out carb by squeezing the bulb?
shipwreck
i don't know, can tell the difference it makes
when i took out of the water it was still leaking engine off, a good stream out of the lower unit.
i unhooked the fuel line at that time. i guess i don't have the answer to your question, i will play with tomorrow and see.
but in the water with the motor off i saw fuel trail and the fuel pump primer got soft , so pumped back up a little
