Re: 1959 3hp light twin
Thank`s,I`m buying one across the country .Pictures look fine,he put new impellor,cleaned carb,and the grease was fine&clear in lower unit.It`s also supposed have 88-90# compression in both.That should be fine.do these take standard 80-90# gear lube in lower?
That throttle slide,does it cut fire off points when it hits that "click" @ stop position?I`m also assuming it should have those green coils&pretty much the same points&condensor kit like I bought local for our 57 model 7.5hp Fleettwin.Thanks again.
