iamdamnsam
Thread starter- Joined
- Jul 22, 2007
- 1
I realize that the buzzer is for low oil or clogged oil filter. Just the sincle blinking light by the oil marks is blinking. It diffenetely is not low oil, so I checked the oil filter. It is a clean as a whistle. However when checking it, there was a rubber gromet on the bottom tube of the filter. I figure that is suppose to be there.
Anyways, I was reading on here about another guy with the buzzer problem that ended up being corrosion in the connections. I was wondering could it also be a wiring failure at the filter? I am going to start checking the wires. I figure this is it since my livewell pump isn't working as well (less then 7 months ole) and the boat did sit for about 5 months.
Any info or tips are much appreciated.
