All it is a Johnson cd-15 5.5hp sat in the barn 10 years. Unearthed to put on 15 footer.To date new coils, 1 new plug wire, points and condenser were beautiful-no pitting, rebuilt carb, new impeller, new carb kit with old corkfloat, spits water good--will start in the start position with the high speed one turn out & low speed 1 1/2 turn out. Idles okay in the start position. Put it on the water today and nothing changes when i adjust the low speed idle. High speed nearly closed 3/4 turn in approximately, runs okay-not great-at wot. I have checked with a homemade spark checker and have white arc about 3/8 inch. Roller does not contact timing plate trying to go to slow or shift position. Timing plate contacts roller at start position. Idles for hour in the tank no issue-Have not done compression check. I have had the carb off three times and checked out everything-looking for help and maybe a picture of low idle speed adjust. Help me what do I do next? Getting frustrated. Thanks
