rmurray
- Joined
- Apr 17, 2007
- 126
I have a Mercruiser 5.7L 260HP Alpha One. The boat seems to be running at the proper idle (fully serviced recently), however, when shifting from forward/reverse into nuetral, the idle drops very low for just a split second before coming up again. 50% of the time, the engine will stall. This can cause frustration when trying to make quick maneuvers at the dock. It almost seems like, during the transition to neutral, the gas gets cut off for just a split second. It seems like it happens more often when coming out of reverse. Is this an easy fix or something more complex? Any suggestions are most welcome. Thanks!
