suzukit dt140
jeffntanya
I have a suzukit dt140.. not sure what year. we bought the boat with a seized engine and thought we could get it rebuilt but the block has a hole in it. the previous owner had put it in the water too early in the spring and when a big strom came it sunk the bank end of the boat. he pulled it out and started it. never drained the oil injection or anything and then two weeks later took it out and it seized after about 20 mins.
my question is what parts can I sell off of it? should I ebay the stainless prop, starter, power tilt /trim
hopalong
Re: suzukit dt140
JUst about any part if it is not water damaged or bad. Just be honest with your sale. Check the lower unit for water, carbs for water etc. If it was only use in fresh water and sunk in fresh water most of the coils and "enclosed" electrical stuff may be good. Trim assy shoud be fine. You would be better off to separate the items to sell them. Sell all the carbs/intake together, coils etc.
Good luck
deejaycee_2000
Re: suzukit dt140
I would say anything on there that still looks decent but people particularly look for the big stuff .... you will probably get most for the CDI, carbs, head (if still good), crank (if still good) and lower unit and prop .......
branda
Re: suzukit dt140
i need a lower unit for my suzuki 2000 if you want to sell yours give me a call at 561 572 7864 David
branda
Re: suzukit dt140
i need a lower unit for my140hp suzuki 2000 if you want to sell yours give me a call at 561 572 7864 David
