how on 1967 lower install
shipwreck
want to know how
: when put the lower unit back on and bolt up how do know the water tube and exhaust tube get seat into rubber grommet ?
Scaaty
Re: how on 1967 lower install
want to know how
Finesse, plain and simple (grease'em)..it will feel right
F_R
You have to look at the water tube as you assemble it. You can see it going into the hole. Not like it's out of sight or anything.
F_R
What engine is it?
That is a very valid question. Some newer-than-1967 motors have plastic guide tubes for the water tubes. However, I can't offhand think of any 1967 models that have (or need) them. Unless I am overlooking one.
shipwreck
if miss and tube dose go in two the hole , you will not get any water to the thermostat?
or if miss the exhaust what would happen?
lexkyboater
If you miss, you could bend or break the water tube, which means no water is getting pumped up into the engine. You'd be able to see that no water is coming out of the exhaust/water port. Then your engine would get hot and would blow the engine hot horn (if you have one), or if not, your engine would sieze if you didn't kill it.
It's hard to miss though, like everyone's saying. Here's some pics of my 1971 Johnson 9.5 HP. Not sure what size motor you have. In the first pic, see the arrow pointing to the water tube grommet? In the second picture, you can just see the water tube to the right of the drive shaft housing and just behind and to the left of the shift rod coupler. When you are reconnecting the lower unit you can look up at the water tube to make sure it goes into the water tube grommet on the water pump housing. Not hard, just be careful, and make sure you have the water tube grommet and drive shaft greased. Should also have a new o-ring on the upper drive shaft, if it has one.
F_R
Again, what motor are we working on? Don't know what you mean by missing the exhaust.
shipwreck
1967 60 hp sport four v-4 model 60733 evinrude
there are two tubes water outlet tube in rear by propeller and one by water pump water inlet
shipwreck
the water inlet is out site because sit so high the outlet you see to point
