Can someone tell me why
kellydee
After diconnecting my water heater and cabin heat and just installing a bypass hose(water circ pump to intake man), I'm idling 15 degrees cooler .There was NO restriction on the lines at all.? Jerry
Don S
Re: Can someone tell me why
Probably had an air bubble in the system. That part of the cooling system uses the engine Circualtion pump as the means to circulate the coolant. If there is an air bubble in the system, it will stop or seriously slow down the water movement.
Having a cabin heater above the level of the heat exchanger can also cause a problem. Bleed fittings in some installations are necessary since the pumps are not positive pressure pumps like a raw water pump with the rubber impeller.
