happycamper
- Joined
- Jul 1, 2007
- 43
I have a '97 Four Winns with a VP 3.0L. I've had the boat for 10 years and it has blown the large diameter circulating hose between the circulating pump and t-stat housing about 5 times. The first two hoses blew while under warranty, but the dealer couldn't figure it out; he just replaced the hose. At high RPM's, the hose is rock hard, especially if the thermostat is closed. When the engine reaches 160F, the pressure is a little less, but still too high.
I've tried to debug this for years, with no success. For peace of mind, I carry 2 spare hoses and I must keep the hose clamps very tight. I've trained my wife to always watch the temp gauge, because if it suddenly drops from 160 down to 120, the hose has blown again.
So far, I've removed and inspected the manifold, riser and all hoses. I pulled the drive and the exhaust appears to be clear. The manifold and impeller were just replaced. I also ran the engine with all belts, t-stat housing and circulating pump removed to check for possible cracks in head or block; there was no air pressure coming from these open ports (ran engine about 20 seconds since there was no water for cooling). Everything flows freely. There's no water in the cylinders or oil.
At this point, I have a strong suspicion that the supply pump is forcing too much water into the t-stat housing at high rpm's. In '99, the dealer put a plastic disc in the supply pump inlet hose. He said it was an OMC/VP fix for the 3.0L since it was getting too much water. I can't find a TSB anywhere on the web about this, and the new local dealer hasn't heard of anything like this.
Any suggestions would be appreciated. It's been a great boat and it's in mint condition since it's always garaged with the cover on.
I do have the OEM manuals, and I've read them cover-to-cover many times.
