whickety2007
Thread starter- Joined
- Jul 28, 2007
- 19
Hi all...I'm new to the forum, but have been reading it off and on for years.
I'm sure someone has a diagnosis for me.
Here is my problem:
I was given a 1989 seaswirl about four years ago with a cracked block and heads. (wasn't winterized, and it cracked everywhere....even the exhaust manifolds. I thought I "learned" the hard way by replacing the long-block (block, and heads) with a junkyard special. All of the marine peripherals were reused.
I ran that motor for half a summer, and ended up spinning a bearing, and seizing it
I then purchased a GM crate 4.3 truck longblock which is pretty close cam wise. I placed brass freeze plugs in it, and once again reused all of the marine peripherals (alt/start/intake/carb/oil pan etc) and have enjoyed it for the past 2 seasons. I ran it in slowly, jumping it on plane quickly not to overtax it, and varying the throttle speed for the first 20 hours. It still has good oil pressure 20-40 at idle, and 50-60 at 3500rpm depending on engine temp. It has never overheated.
It recently devoloped what I'll call a knocking noise at idle. It just runs a little rough below 700 rpms and a light knock like the timing slipped. (it didn't I checked it) I thought, at first is was the esa system (which has never worked) actually malfuntioning because of the fact that over 1000 rpms it seems to sound fine. I took it into my local marine mechanic, and he pulled the drive. He advised that the low speed knock seems to have gotten better, but its still there. ( i had replaced the gimble bearing with the original install two years ago. either way the drive has been eliminated as the source) He also thinks the alignment, and u-joint is ok. He thinks the engine coupler, or flywheel has come loose, and wants to pull the engine. Now I know that I torqued the bolts right, and used loc-tight red on the threads. So is there a better way to diagnose the knock/rumble?
Also he wants 4-500$ to pull the motor...sound reasonable?
Here is my problem:
