Re: 1988 force 125 lower unit
Almost any one piece lower unit from late Chrysler up tp 88 Force three or four cylinder engine will fit; they never changed the drive shaft, gearcase, or internals. Everything just bolts right up. The only changes were the shape of the skeg. If you use a lower unit from an 85 Horse Force, check it by spinning the drive shaft and see how many turns it takes to turn the prop shaft one turn. On most, the gear ratio is 2-1 rather than the 1.78 to 1 of your lower unit. You will need to use a prop with about 2 in pitch more. The upside is that you will gain about 2 MPH. The downside is that you will use more gas at WOT.
