2005 Johnson Bombardier 90 hp evaluation
georgiaboy
I bought a Triton with a 2005 Johnson Bombardier 90 hp. Since this is my first boat purchase sine my 1982 Tracker i wonder how my motor stacks up to other motors. Should have done some research but loved the boat and it was a good deal. So tell me what you know about these motors and are there any special things particular to the Johnsons. It has very low hours and I have noticed it seems to run better every time I use it. That could partly be due to my learning the rig in general. Don't hesitate to be critical if I make a mistake.
georgiaboy
Re: 2005 Johnson Bombardier 90 hp evaluation
some one has to know something about these engines.
You are not telling us what specifically you are concerned about or interested in. It's a 60 degree V4 oil injected engine of 105.4 cubic inches (1726cc). It's recommended wide open throttle rpm is 4500 - 5500 rpm but it can be propped for 5800 RPM. It has a 2.0:1 gear case but may have a 2.25:1 optionally. It has two dual throat carbs and is fitted with a 20A alternator with regulated output. It weighs about 335 pounds. It's a good motor. Keep it decarbed, use a fuel system conditioner to keep the fuel system and carbs clean and it will run for years.
it's the old proven to run forever Johnson with proper maintainance.
georgiaboy
thanks guys- I guess I was just curious as to how it compares to the other outboards out there.
