mole2
Thread starter- Joined
- Dec 21, 2003
- 153
I have a 2005 Trophy with a 4.3L 190hp FWC engine and Alpha 1 Gen II drive and I'm told it should have an anode in the heat exchanger. Other than the pressure cap, the only plug I see on the exchanger is a brass plug located on the starboard side. You can see it in the picture below. I removed that plug but there is no anode under it nor anywhere to install one. This is a stock Mercruiser FWC full system with a belt driven raw water pump that was ordered by me as an option from Trophy when the boat was new. Can anyone point me to where the anode is installed or, if it's supposed to be where that bronze plug is, what i need to purchase in order to install one. Thanks.
