crocket15
Thread starter- Joined
- Jul 24, 2007
- 19
During my first substantial time of having it out on the water it started up just fine. The idle seemed a little weak as it died while switching gears, but then after working great for about 20-30 min at full speed it began to slow down in incraments then it just cut out. After a few minutes of trying to restart it, it finally fired and made it another 5 min or so before it cut out for good. I believe the pressure in my fuel tank was pretty good as there was a lengthy puff as i unscrewed my gas cap. Looking down as it ran it seemed to shoot out quite a bit of water, but then again it was my first time and I don't exactly know how and where everything should be squiring. In my frantic as a newcomer to boats i messed up my slow and high speed adjustments in the process of trying to keep her running as she began to die. This motor sat in storage for a year or so, and the gas was probably a year old as well. I may have had a slightly leaner oil mixture than the motor requires due to some bad advice form another forum. THe filter inside the bulb seems clean but I have not taken anything else apart yet. Does anyone have some suggestions as to what might be the problem or what to check and look for? I have a tank to run it in, and as i said my knobs are a little messed up at the moment. How many turns from fully tight, or "all the way screwed in", should they be? The spark plugs are in the same state as the rest of my motor "neglected". I took one out and it was fully black all around, there should probably be a little shimmer would be my guess. I hope i explained enough, and I hope someone can help me out, it would be very appreciated.
