Please hang with me as my verbiage won?t be technically sound as I am mechanically illiterate.
I have a 1986 Mercruiser 4.3L 205HP engine that was rebuilt this past winter. Since the rebuilds (related or not), I?ve had intermittent starting and dying issues. Early on, the engine always started and then might die while warming up at idle, under WOT (only once), or while trolling at low RPMs. The engine would die as if was **** off with no sputter or anything. It always seemed to restart right away, but as the season went on, it seemed like I needed to ?play? with some wires (related or not) to get it to go.
Lately, it hasn?t been starting and when it eventually does (hours later literally), it sometimes dies and sometimes doesn?t. To note, the engine cranks and cranks and just doesn?t turn over. I was finally able to reproduce the issue with my mechanic present as every time he was there, it worked fine. He has determined that we don?t have a spark coming from the coil. The first time he diagnosed this, the spark was not there and a few tries later he had a spark and the engine would start right up.
Early in the season, my mechanic replaced my ignition switch as this issue first started where it would crank but not get the spark signal needed. A couple of quick bursts with the key would make it start. Replacing the switch worked for that issue (related or not). My mechanic replaced the coil on Saturday and the boat started right up and we thought we were OK. Right when he was getting ready to leave, it died again and there was no spark shown from the coil once more.
The engine has a Thunderbolt ignition box and we discussed swapping the box with the one on the port engine to rule it out, but my mechanic said he has never seen one of these fail. I want the swap to rule it out, but it did not happen.
My mechanically illiterate pea brain thinks there has to be some kind of wire shorting out coming into the coil. I spent lots of time Saturday evening ?looking? at all the wires because the boat did not start again then or yesterday for that matter when I was alone.
All ideas are greatly appreciated. We?re at wits end.
Thanks,
Joe
Thanks,
Joe
