Hot wires
kay
I`m not sure if this belongs here...but i figured i`d give it a shot.The wires for my accesories seems to get hot even though the switch to them are turned off.There all(lights,bildge pump,depth finder,motor) running from the same battery.I`m baffled to what is causing the wires to get hot to the touch...Any help or suggestions would be greatly appreciated.
Bluedog
Re: Hot wires
Check all connections. Loose one will produce heat, Is the wire large enough? Also since you said the switch was off, put a Voltmeter to the wires and make sure you do not have voltage through a pinched wire making contact with one that is energized.
kay
Re: Hot wires
I`ll double check the size of the wires. But i`m pretty sure that they are of the same size as the ones that came with the accesories.Thanks and i`ll post up later to see what i find.
Sig_Mech
Re: Hot wires
Kay, without seeing your set up it will be a little harder to troubleshoot but let's give it a try. First off, take Bulldogs advice and check all your connections, the hot to the battery and all grounds. Make sure they are clean and tight. While you are at it, make sure everything is wired correctly with hot feeds to positive and grounds to negative. Now make sure that the feed wires (hot) to all your accessories are the correct size. Do you have a breaker panel or a fuse panel? If not, how are you getting power to everything? Do all the hot leads go back to the battery positive or are they spliced to one wire that goes to the battery positive? Are all the grounds tied to one wire then grounded or are all grounds separate? Do you have lighted switches? Some of these switches use a common ground and/or hot for the switch light, be sure to check these connections too.
If you don't have a breaker/fuse panel installed then I would recommend you look at putting one in. It will help protect your equipment from shorts and will make solving problems like this alot easier. Good luck checking your shorts.
kay
Re: Hot wires
Each of the positive wires(except the battery and night lightpole in the back) runs to a switch then to the battery.Same thing goes for the negative or ground.No wires are spliced into each other.They are each running separates.The switches are not lighted.They just have the 2 connectors for the positive and accessory wire.The ground goes straight to the battery.I`m going to look into a fuse panel as you and a couple of fellas have suggested.I`ll post back what i find out tonight.Thanks agin for the quick responses:)
