Hello to all. I have a 2003 Searay 182SRX w/ Mercruiser 4.3L 190hp Alpha One. The engine has recently developed a very high oil pressure situation. So here is a run down and I would like to know what I should do next.
At idle, I am seeing about 60 PSI. At 1/3 throttle the pressure is up to 80 PSI (max of the electric gauge) and at about 1/2 and above the pressure climbs all the way up to 90 PSI.
I changed the oil and changed the filter (old one was a Casite, new one is a K&N) and still have the same issue. I have checked the pressure with a mechanical oil pressure gauge as most of the posts suggest and have gotten the same readings as my electric gauge.
I am going to try to call Mercury and any service shops that I can, but I am running out of possible things to check without having to start tearing apart the engine.
The only other thing that I can think of is that the bypass pressure valve is stuck, but I don't know how I would check this.
Any help would be greatly appreciated.
